hi all can anyone tell me the size of the filter for the Sony handycam FDR-AX33 4K , I think it is 52mm
PJ
hi all first time, can anyone help with the size filer for the Sony handycam FDR-AX33 4K I think it is 52mm
PJ
Hello @pam193,
if a camcorder has a thread on the inner side of the lens, you can simply take a look at the front of the lens - it will have the value written on it.
For the FDR AX33 it though looks like there is no such thread.
- Nic
