Hello to all members of the community!
FDR-AX33 has not a Timelapse function.
Is there a way to create a timelapse video with this camera?
As far as I know, I can use a software to speed up the video but there is not an application to make the camera take stills automatically and create the video after that.
Does anyone have any idea?
Hi @ioagount,
there are several timelapse apps ffor Sony cameras, which work like the Sony PlaMemories App but 'click' on 'Record' for you in a set interval.
This one should work: https://play.google.com/store/apps/details?id=com.thibaudperso.sonycamera
- Nic
Yes!
This is the first application that I used but it didn't work for FDR-AX33, unfortunately.
The developer's list does not include my camera.
Any other ?
