Is it possible to use the fdr-ax33 stream over wifi without ustream? I would like to stream directly to my computer (obs) for edit on the fly.
Hello @Web-fj,
that is not possible, yet you could use e.g. an Elgato CAMLINK and a HDMI cable to get the video feed into your computer and use it with OBS.
- Nic
Dear Nic,
Thanks for your suggestion! I found an 4k version that will work. Is there a way to have it wireless? That would be very handy...
Br Frank
