looking for handycam driver for windows 7 ..digital handycam modeldcr-trv16e grateful for any help
ANTO
Hi Anto, welcome to the Sony Forums
Unfortunately USB drivers for older cameras tend not to be updated to comply with newer operating systems. In common with most MiniDV camcorders, there isn't a W7 driver for the TRV16E that I'm aware of.
However if your PC has a firewire port, you can connect via the camera's DV-out port without need for a driver.
If you don't have a firewire port it's often possible to fit one, either by installing a card in your desktop or via a PCMCIA card adaptor in a laptop.
If these options aren't available to you for some reason, your only other recourse is a lower-quality analogue transfer using the AV cable that came with the camera – a 3.5mm jack with red, yellow and white phono plugs.
The analogue signal will be fine for viewing on a TV, but will need to be re-converted to a digital signal using a 'video capture device', via your USB port, before you can import and edit the video on a PC.
If you need any further help, just shout
Mick
Mick
