In playing mode my camera is changing from digital 8 to Hi8 mode, which makes it impossible to copy my old tapes.
Regards hogneper
Hi there,
I'll look into this and update the thread if I can find an answer for you. In the meantime, I'd recommend getting in touch with the support team here who will be best to advise on this.
Best wishes,
Sean
Hi @hogneper,
did you by chance set the playback mode to Hi8? The respective setting can be found in the player settings under "PB MODE". This should be set to "AUTO".
darkframe
