I have a DCR-HC14E Handy Cam circa 2004 and about 40 Mini DV cassettes full of family memories.
I am struggling to connect the DCR-HC14E to my PC.
When I use the USB to Fire Wire connection I get the following pop up on my computer screen:
'USB device not recognised - The last USB device you connected to this computer malfunctioned and Windows does not recognise it.'
It is a brand new cable so should be no problem.
I wonder if it is because I'm using Windows 11 or possibly there's a hardware issue and I need to buy a more modern camcorder to transfer the cassettes?
Many thanks for any advice as I'm at the end of my tether.
Thanks
Many thanks - I'll give that a try.
