Hii...
Regarding HDR-PJ260VE... is danish menu included on this cam. ?
Thanks
Lars
Hi Lars, welcome to the Sony Forums
I believe Danish is a supported display language across the Sony range, yes.
Out of interest, do you have a reason to suspect the PJ260b doesn't
Mick
Well just got the cam yesterday :-), and in the setup Danish language is not available under "Language Setting"
Could it be a parallel import cam. ?
Cheers Lars
