- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
January 2011
January 2011
Create AVCHD format disc
Can't create an AVCHD format disc either from PMB or direct from Handycam. Get error message PMBHDAuthor.exe has encountered a problem and needs to close. Any ideas?
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
February 2011
February 2011
You did not say model but I guess it is HD camera Sony. So, if You use PMB You should best use AVCHD supported disc and mybe Your grafic card on PC does not support avchd format//
http://support.d-imaging.sony.co.jp/www/disoft/int/pmb/feature/index.html
