Can someone please advise me how to copy from my Sony Camcorder HDR-CX240E to my Sony DVD Recorder RDR-HXD890 please.
Hi Tony and welcome.
Just connect the camera to the DVD Recorder by USB cable.
Your camera has a short built-in USB cable and when you bought the camera, it would have come with a USB extension lead for this purpose.
Use the supplied extension cable to connect to the DVD Recorder
The USB socket is inside the front flap of your DVD Recorder - (18) here:-
Good Luck!
P.S. If you have mislaid the manuals for both items, you can download them here:-
Camera - http://pdf.crse.com/manuals/4531548111.pdf
DVD Recorder - http://pdf.crse.com/manuals/3295080121.pdf
You will find full instructions and limitations in the DVD Recorder Manual.
Unfortunately, no this did not work. We have the cables you mentioned and we also have both Manuals - but all we are getting is a lot of dots on the screen. Might this be because there is also a video recorder and YouView box connected as well? The Sony shop in Hereford have told us that this is not a possibility and we need to put it on the computer and then use an App??? In anticipation - thanks!
