Can my PC100E communicate with Windows 10 via Firewire? I seem to unable to connect with legacy driver.
Hi there,
I'll look into this and a community member should get back to you.
Best wishes,
M
Hi John
Giving it a shot is all you can do at the moment, but I don't think the compatibility between such an old cam and Windows 10 is all that reliable. I'm not surprised it doesn't work at this stage.
Win_88
I found an old version Roxio that sees the camera and captures video.
Hi @John_Hayden,
it would be great if you could tell us about which software and version you are talking exactly. Additionally I'd like to know which Firewire driver you are using. Well, I know about the old legacy driver but my new PC, built from scratch, has got a clean Win 10 system and there's no Firewire driver at all. Are you maybe using the Microsoft driver which is still available for Win 8.1? I heard that that one can (!) be working in Win 10 as well.
Thank you!
darkframe
