Hi
I've got an HD, 5.1 Handycam and want to create HD, 5.1 movies that I can watch on my PS3. I can use PlayMemories to create Mylists but can anyone recommend a programme that will:
1. Put all of the individual files together into one continuous movie.
2. Maintain the HD quality
3. Keep the 5.1 audio track
4. Allow you to finalise it as a new video file that you can transfer between devices.
I know that technically you can do this with Playmemories on the PS3 but because of the file size, you can't transfer it off the PS3 easily. It would be useful to be able to create it on a PC and save it to an external drive which you can then take around and use with other PCs and PS3s.
Thanks, I'm new to all of this so would appreciate some help.
