Hi all,
I have ordered a brand new Sony HDR-TD 10 camcorder, and also a new PC with a GeForce GTX 560Ti graphics card and a 3D LG Full HD Monitor (23 inch).
I just wonder how to edit 3D on my PC?
Does someone know, if the Nvidia 3D Vision Kit (non PRO version) would work?
http://www.nvidia.com/object/3d-vision-main.html
As the pro version would also need a quattro nVidia card...
Thanks in advance,
Dary
The footage recorded should be saved as a side by side image so try playing it through something like Windows Media Player to verify.
In theory, you should then be able to edit in any program since its a normal video feed with both 3D angles beside each other. Sony Vegas is available as a 30 day trial so could give it a go.
I have not had a chance to try it out to confirm the results but maybe you could post up what happens after you have tried?
please could you give more detailt about how to get this handycam,
I'm not able to find avaialble stock.
suppliers as amazon says that it will be avaialble soon.
