Mine too.. I dont know how to fix this bugs..
Hi @faijanali97 & @erch, welcome to the community.
I am very sorry to hear you are facing this issue.
If the software repair using Xperia Companion has not fixed the problem, then it is very likely a hardware fault. I recommend you contact your Local support team to arrange for an assessment.
Hi, I have Xperia C3. The problem I am facing is that the batter drain super fast after it reaches 20%. Within a minute or two my phone gets switch off automatically. I am tired with this issue. The second issue I am facing is with audio. The person on the other side cannot hear me properly. Please help me to get rid of these two problem.
Hello, I have the same problem with you, did you find the way to fix it??
Thank you
My battery is draining fast while playing online games don't know what to do.Do u know any battery saver or something else
