Hi Everybody!
Recently I rooted my Xperia C3 DUAL (D2502). I installed the application form playstore AParted and accidentally deleted my internal storage partition.
Now on my device is not detectable no charging, no volumn up, down or power keys working, No fastboot or flashmode and even usb is not detecting. It shows red light for a moment and gone when i connect with PC.
How can i recover it? Any genius there?
XDA developers have posts about Xperia Z but there is no such information about Xperia C3 DUAL (D2502).
What are the test points for Xperia C3 D2502 Dual mobile? Can I recover it with SETool?
Anybody, any genius there in the world who can help?
Thanks,
Sorry to say but if Flashmode or Fastboot mode doesn't work then you have a hard bricked device - you would need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
I found the solution for Xperia Z on XDA
[GUIDE] Z Ultra and Z1 HARD BRICK RECOVERY
So, I just want to know if there is solution for Xperia C3 Dual (D2502).
Thanks,
Non that I'm aware of sorry and XDA is the best place for info of this nature
I've also started thread on XDA but waiting for genius for response.
Anybody here can resolve it?
Thanks,
Good luck but I doubt you'll resolve this via personal means
If Xperia Z has the solution then there must be a solution for Xperia C3.
Thanks,
I have the same problem but when I plug the phone it tells me a constant red LED
