Hi
I Have XPERIA C Device I M Facing The Problem That Screen Is Being Zoom Automatically While Typing Or Daling Number ....... Please Help I Have Replace The Mother Board Too .
You have enabled magnification gestures from accesibility.
Yes I Have Enable Magnification Gestures
Okay I will Try This & Let You Know But What Is The Purpose Of Magnification Gestures ............
Probably for people that don't see that good,they can zoom in.
Thank You So Much I Will Try & Let You Now
Keep us updated.
Yes Working Now Fine Thanks Alexdon
Cool.
