My xperia device get totally hang...............
touch , power button and volume button are also not working..
battery is fixed so not able to remove and force start it.....
please give me a solution.....
thank u... power+vol up ... simple solution
Thanks for the solution!
Thank Bro !!
Hi, I have xperia C. Today it was suddenly got hanged, so i press the reset button, which on back side of phone.
Then it showed only Sony logo and then continuosly shows xperia flame theme, untill total battery discharge.
Please suggest the solution. I have done reboot a month before.
thanks.. it woks
