my wife's Xperia C4 seems lately to have a problem connecting to our wifi. The network is there, it shows as 2saved", when I try to connect is says "scanning", then switches to "saved", but won't connect. I have to turn off wifi, then do a restart, then turn wifi on again, and it connects, but randomly disconnects again, and I have to repeat the whole process. very frustrating.
ไม่สามารถ สแกนไวไฟใด้ ไม่สามารสเชื่อมต่อไวไฟที่ใช้อยู่ใด้(ไวไฟบ้าน)
ขอบคุณครับ
Can not scan, flammable, can not connect, use flammable (flammable)
Thank you
GT
