Merhaba arkadaslar ben volkan, bugün katıldım aranıza.wifi baglantı hızı cok dusuk, sinyal gucu mukemmel. Aynı konumdan baska cihazla gırıyorum hıc bır sorun olmuyor. Kendı cıhazımdan denediğim zaman sinyal gucu mukemmel fakat baglantı hızı cok dusuk. Hıc bır yere bağlanamıyorum,bır onerınız varmı? Tesekkur ederim.
Hello friends I am joining volcano today, the connection speed of wifi is very low, the signal strength is perfect. I do not have any problems in the same location. The signal strength is great when I try it from my code, but the link speed is very low. I do not get to connect one by one, do you have any suggestions? Thank you.
GT
@Volkan16wrote:
Merhaba arkadaslar ben volkan, bugün katıldım aranıza.wifi baglantı hızı cok dusuk, sinyal gucu mukemmel. Aynı konumdan baska cihazla gırıyorum hıc bır sorun olmuyor. Kendı cıhazımdan denediğim zaman sinyal gucu mukemmel fakat baglantı hızı cok dusuk. Hıc bır yere bağlanamıyorum,bır onerınız varmı? Tesekkur ederim.Hello friends I am joining volcano today, the connection speed of wifi is very low, the signal strength is perfect. I do not have any problems in the same location. The signal strength is great when I try it from my code, but the link speed is very low. I do not get to connect one by one, do you have any suggestions? Thank you.
GT
About wifi connection i advise you to talk with yours internet provider. Coz Sony don't give you internet. Wifi is just a feature which is in yours smartphone, but internet connection giving you yours internet provider. Keep in mind that wifi speed depends which plan you have from yours internet provider (for example if you have 100mb speed in wifi it can be about 25 - 50mb and ect. Xperia C5 havn't AC protocol (5GHz band), so speed can drop half of yours internet speed plan), how many devices is connected in the same wifi, how far you are from router and modem, is any interference and many others things. As i mentioned to help you can with this yours internet provider
