Hi Support team,
My mobile not working properly. Everytime I'm encountering Unfortunately System UI has Stopped popup. I'm facing this problem since 15 days. I need a solution to this issue.
Kindly consider my request.
Hola: tengo el mismo problema en mi C5 Dual, hau algúna forma de arreglarlo?
Gracias.
Hi, I have the same problem on my Dual C5, is there any way to fix it?
Thank you.
gt
