Hello! I recently bought a new sony xperia c. Yesterday when i was installing new Version it stucked at 0% and i cant do anything. I have the update service in my computer but i cant find my phone. I turned it off (and from back button) but nothing happend. i Tried pressing power on and volume up key but nothing happend again. Can you tell me something to do?
Thanks for your time!
liakouras2909
Connect the phone to a wall charger > press and hold power & volume up > let it charge for 2 to 3 hours then repair it with SUS
Thanks for your help! I will try it and i will tell you what happend!
Everything is fine! Everything works fine! Thanks!
Excellent
