Hi! I´m in a hurry! I lost my charger so i need to buy a new one, but a don´t know which one i must buy. Can someone help me by sending the specificaiions of the charger? I want want to get the right and original one. My celular is a Sony Xperia C4 5306
Hi @LORD_VERZERKER, sorry to hear about what has happened.
The charger that is included in the box way vary between markets, so I'm not 100% sure which one was included together with your device.
The EP880 which is a normal standard wall mounted charger was included with a lot of our devices before the UCH20 started to be included and you can find the specifications for both chargers below.
EP880/UCH20
Output 5.0DVC = 1500mA
Note! VDC=Volts Direct Current, mA=milliamps
You can use any Xperia charger with your Xperia device, but if you want to make sure that you buy the same one as you had previously, get in touch with your Local support team and they will able to provide information about the name of your previous charger.
I hope that helps!
