It's hard for me to say if there is anything wrong with the phone. The phone does heat up when using power hungry apps, but it should of course not be so hot that you can't use the phone. It does have built in functions to prevent over heating which will close down apps and eventually the phone when getting to hot. If you believe there is something wrong with the phone you can contact your local support to get information on how to send the phone to a service center.
Well then it seems like there's something wrong indeed. I suggest that you try to repair the phone software using PC Companion..
Before repairing your device you may want to backup your information first. Check out this topic for more information on how to.
How to backup?
If the issue should still remain I think that this needs to be examined and fixed at a repair center. For more information about how to submit your phone for repair and where, contact your local support team.
Hello guys ,
i am planning to purchase C4 duel in coming 3-4 days .. i am only worried about is heard it is having heaopting issue ..
tried in mobile store and handlled it for some 10-15 min and found some gud heating at top portion..
whats all your opinion ??
hi whats the latest update ? is ur problem solved..? .. i just checked with temp. measuring instruments .. temp. touching to 42-43degc. for 10min browsing .
My phone heats up for everything mentioned above reasons, addition to that sometimes it heats up without any reason, it heats up when it is inside my pocket..
Going to re-install the Software.. if it does not work?
