I want to change the phone's battery. How can I tell if the battery is original or not? Could you write if you have a site or vendor that you can recommend?
Hi @User638,
If you want to replace the battery in your device I recommend that you get in contact with your Local support team. They can direct you to your nearest authorized service center to have your battery replaced.
Let me know if there is anything else you are wondering about.
Hi @User638,
Need to change battery
Hi @Sahir82,
If you need to change the battery in your device, please get in touch with your Local support team and they will either arrange a repair for you, or inform you of the location of the closest authorized service centre in your region!
Let me know if that helps!
