Hi please help me i am using sony xperia C3 D2533...my mobils NFC icon not showing After update Lolipop And Before Update Lolpope..after buying my mobile i see some problem...exa..hanging )then i go to repire my mobile to sony service senter ..i repair my Mobils software 2 times. first time i repair Kitkat Software>>reason..hanging,,after repairing NFC icon not showing....Then i repair Again..reason..NFC icon not showing...this time the sony service center repair and install new version Lollipop software....but its not work..its same NFC icon not showing..sony service center say no problem..many firmwares like different...............please say what can i do....
Regarding the sound issue I think alexdon is right. Sometimes it doesn't play fully but it should not be any real issue.
When you have all these question it can be a good idea to give your local Xperia support a call, they'll answer all your questions right away. You can find contact information here: Local support.
There's nothing wrong with your phone, the NFC icon on the status bar its no longer displayed.
This is something asked before (on older devices and older firmwares). Some operators have chosen to still show the icon.
i want to download new latest firmware, using xperia firmware downloader.........and install this firmwae using flashtool,is it safe way to download and install firmware...?
Isn't the update available via PCC?
Are you referring to EMMA? if you are it is NOT a good idea, you will have to unlock the bootloader, assuming that your phone has never been locked to a carrier, but the DRM keys will be gone forever.
i am trying to update and repair my mobile using pc companion but nothing to change.However,the NFC icon not showing..
When I bought my mobile phone,this time the NFS icon is shown...but after software the NFS icon is showing....is that sony service centers software fault..
Did you even read the above posts? The icon is not shown in most of the devices right now. Some of the network carriers have chosen to still show it.
is my device running on letest software....???
