hi i ran into an issue with my device where it was working perfectly fine and i was using it and it died in my hand while using not battery issue i could hear the sounds and my touch pad was still working just display went dark i turned it off and when i try turning it on it flashes a light as it does with power on then the display stops working again and i can hear the phone play the boot music and after be fully functional just with no display showing any help on this since its not under warranty anymore what could the problem be no cracks on screen or any kind of damage either on the screen side of things
I'm sorry to hear that but it does seem to be a hardware related issue, you could repair the phone with Xperia Companion to narrow down the issue, but most likely you will have to get it inspected/repaired by your >>> local support
لا يتوفر خدمه
No service available
gt
