first of all i started getting message (phone is shutting down due to high temperature). and i repaired my phone through Xperia-companion, after that i am not facing high temperature message in last 2 hrs hope i dont get that issue again, But i have found new issue , my mobile is not charging , during phone off, if i connect charger during start screen led light turns on like its charging, after charging icon get pops up then LED light turns off but still charging icon shows but wont charge........ but also MTP/MSC connects with pc. please help me ASAP.
The heat warning it's normal, if you are constantly syncing or playing videos, games, etc the phone will heat up and you'll get that message to prevent heat damage to your phone, as for the other issues, it'll be wise to contact your Local support
Dear? Sony Xperia sometimes i experience in my phone Sony Xperia C3 Dual in 99% of charging his stopping to charge in the last few days, can you please let me helping me? Sony
Hi SahilJoshi,
Try doing the following.
Hold the Power button and Volume + key for around 15 seconds, once done put the device on charge for around two hours.
After this point, you can attempt to power on the device and see if it has charge, if the device does not turn on I suggest running through a software repair on the handset.
If this fails please contact Customer Care for further help.
This is really unfortunate, in this case I can only advise that you speak with Customer Care and maybe have the device sent in for repairs.
Please use my Signature below to find contact details for your region.
