My Experia c5303 will not turn on.
The notification light glows green but nothing else. It glows red when the charger is plugged in. Holding down the volume up and power buttons makes no difference and when the back is removed and the power off button IS held in the green light stays on.
It just does nothing. Please help.
Keep it charging for one hour,repair with sony update service after.
my xperia c is having same problem...i have tried this but nothing happened 😕
Try to charge the phone at a wall socket for 1 hour.After that,force shutdown the device(press the little button on the back).Repair via sony update service:
http://www.sonymobile.com/gb/tools/update-service/
none of this worked for me as computer said nnot connected all the time.
Hold volume up key +power key for 10-15 secs, this will virtually disconnect and reconnect battery, then power on using power key
it worked for me
thanks and regards
Anuj Dubey
hey, same problem is going on with me and the sony update service is no more available.
My phone is stucked on boot screen logo . .and nothing , its going on and on and on . . .. and nothing.
Please help me out of this.
just repair it with the pcc or download ftf file and flash it via flashtool...may be the software is corrupted
I have the same problem my phone wont turn on the advice is update the phone system I can't update because my pc wont recognize the phone via usb connect unless it will turn on how could I do your sugestion
