MY XPERIA C IS NOT STARTING ON..
SONY COMPANION IS NOT DETECTING MY XPERIA C …..I TRIED ALL THE POSSIBILITIES ….WHAT TO DO NEXT ??
iTS ONLY SHOWING RED LED BLINK AT EVERY 10-15 SECONDS .
WHAT TO DO NEXT ?? PLEASE DO REPLY ASAP
Hold power and volume up for around 15 seconds then try to start your device if that fails redo the 1st part and then let it charge for 2 hours and try turning it on again - If that fails then report back for instructions on how to perform a system repair
NOPE IT DIDNT WORK ......PLEASE GUIDE ME FOR SYSTEM REPAIR.
(ps-sony pc companion is not detecting my phone)
To perform a system repair which will factory reset your phone
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
flash tool is not detecting my phone plzz help...
thanks
same problem with my xperia c,neither flash tool nor phone repair of sony not detecting my phone.please help me
@manilsood wrote:flash tool is not detecting my phone plzz help...
thanks
solution is Replace new EMMC
bro i visited coustmer care centre but very bad service.............he said that they will need to replace board of my device....
