Sony c4 charging only when off
@NOGINOG wrote:Sony c4 charging only when off
Sony xperia c4 sac pin khi tat nguon
Sony xperia c4 sac battery when tat fooled
gt
What please make it clear what your trying to say
Hi @NOGINOG, sorry to hear about this.
Could you try charging your device while its rebooted in safe mode? Just so we can make sure that a downloaded application isn't the cause of this.
If you are using a USB cable and a USB port to charge your device, try using the wall mounted charger that was in included with your device as this will charge the device a bit faster compared to a USB port.
@Haidang, your question has been translated to English as this is an International forum, but I'm still not exactly sure what behaviour you are experiencing, could you please elaborate a bit? Thanks.
