My phone xperia c3 has software problems like whenever I start my phone the apps which are in apps tray just blink on the homescreen itself also the almost all time the used ram is more than 690mb and display quality decreased after some time usage of the new firmware but the last two problems were not in earlier firmware.
Hi.... Issue One: - I can not transfer data to external memory device internal memory even when you press the button transfer data to memory show transfer images, video, songs and applications but can not identify any choice .... Issue two: - When connecting any external USB Link does not appear on your phone or mobile device Along with eliminating the settings for activating the external conduction is not connected inside the device settings Please solution because of the suffering severe problems above and thank you
It is best to perform software repair, ONLY AT service center. Yes! I done it using xperia companion too, but it doesn't solve the problems. So go and repair your software at service center, the phone will be awesome.
