Hi everyone,
I have a Sony Xperia C5 Ultra. Yesterday I updated my phone to 29.2.A.0.166 from PC. After than my sms application is not working. I cant give or take any SMS's from anywhere.
Did somebody experience this thing? Can we solve problem?
By the way I textted to help desk if some answer from there, i will updating here.
Thanks
Update on 05.02.2018: I repaired my phone with Xperia Companion and problem was solved. Thanks for everyone.
I am also having the same problem, new system update (ı dont dont why it is published) needs to be corrected immediately or someone from the sony needs to direct us.
Update: I have solved my problem with software repair on Xperia Companion.
try to grant permission on the sms app
settings>app>app permissions
and or
try to clear data of sms app, settings>apps>messages>clear data
make sure your network settings are set correctly
Hello!
I have the same problem after update and nothing helps.
I tried to restore the firmware, but the problem persisted.
Please, help!
Sorry for my english)
been trying to solve this the whole day, no luck so far. any help is appreciated!
I got mine solved after 5 resets altogether. SMS is now working, but all previous texts gone.
I have the same problem too after the update. I cannot send or receive any text messages 😕
Hi my friend,
I tried this solution but it was'nt solve problem. I tried repair my phone with Xperia Companion, and it works.
Thanks for your time.
Dear Sir, last 15 days default sms not working in my mobile.
