I had xperia C4 dual nearly a year ago and i looked forward using it with android 6.
todoy my dream has been achieved and finally updated my mobile to the latest sofware version (android 6).
However, there is a problem has ocured directly after updates had finished.
my moblie ejecting my 64 GB sanDisk SD card unexpectedly every time i turned it on. althought the same SD card was working well since i bought it two months ago with the old software before updating.
Could you please help me to solve this problem ?
The messege appeared on mobile device display is:
Sandisk sd card unexpectedly removed
Unmount SanDisk SD card before removing to avoiding data loss
C4 android
are you saying that after the last update your phone doesn't recognize the SD card?
i had the same problem but it didnot work by formating
