Hi, I bought a Xperia c3 but dont work the gps. I cant use apps like waze or Google maps. Can you Help me please?
I've been having the same problem since the firmware update. I can't use gps. Maps only works with mobile and wifi networks but unaccurately. Sony, please, launch a patch to fix this bug.
@ J.R.R. Tolkien:
Dude it seems that you are the only person knowing that we need internet connection and location should be enable before using Maps.
Just don't try to be oversmart. The problem is with many users. Reply if you have the solution otherwise just make your mouth shut.
@vikassaikapian wrote:@ J.R.R. Tolkien:
Careful now, you just very nearly tagged a moderator in order to tell him to shut his trap whilst offering advice.
First of all, you quoted the name in his SIGNATURE.
Secondly, he's trying to troubleshoot the problem from roots, if it's not helping you it might help others.
Lastly, watch your language, because it's against this forum's guidelines.
I didn't find him giving a solution except asking the question which he thinks the user might don't know. But still the user says yes he met all the condition which is required for the navigation. after that no reply from him. so kindly provide a solution after that also.
