- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
1. Whenever I close the torch, my mobile lags for like 7-10 seconds.
2. When i unlock the phone and try to open contacts then the message is displayed that the contacts have stopped.
3. Sometimes my phone hangs when i receive calls.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi shivani16,
Have you tried clearing the cache for WhatsApp? If not, please try this. If that hasn't helped, I advise booting the phone in Safe Mode to determine whether this is something being caused by a third party app or not. To boot your phone in safe mode press the power key until the Power Off message appears > hold your finger on Power Off for 2-3 seconds until Reboot to safe mode?' appears > tap OK. To exit Safe Mode just power the phone off & then on normally.
Let us know whether the issue was present in Safe Mode or not.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I suggest that you try to repair the phone software using PC Companion..
Before repairing your device you may want to backup your information first. Check out this topic for more information on how to.
How to backup?
If the issue should still remain I think that this needs to be examined and fixed at a repair center. For more information about how to submit your phone for repair and where, contact your local support team.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
i have purchased finally new xperia C4 what i do observe is contact is getting slow in opening .. exactly 4 sec just to open contact list..
i am still checking phone and shall revert if contact issue gets resolved.
one more thing .. phone gets noticable warm at top side from camera lens to 2-3cm below within 10min of use.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
And today I had major issue camera is not working after talking with customer support I got resolution to test it by *#*#7378423#*#* after number of attempt of safe mode reboot and hard reset issue is still unsolve
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
What should I do?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi shivani16,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have cleared the cache for WhatsApp and now its working fine.👌
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Tags:
- Bom dia
- como proceder eu comprei o mesmo no dia 4 de dezembro de 2015.
- ele fica toda hora reiniciando e desligando. Ainda está na garantia
- quando a bateria descarrega total e coloca pra carregar
- quando coloco pra carregar automaticamente a bateria fica com 90% de carga e logo fica 100% e não dura 20 minutos a carga. Não consigo ligar ele enquanto ta carregando
- quando conecto o carregador no celular ele desliga sozinho
- se tiver carregando e eu atender ou fazer alguma ligação ele desliga também
- ta demorando muito pra reiniciar
- Tem duas semanas que meu telefone começou a apresentar problemas. A bateria começou a descarregar muito rápido
