after you upgrade the phone first card worked but after a while stopped how to fix it or when will be fixed?
I have the problem,,do you find any solution.
I updated my phone now says xd card is corrupted 128gb tried formatting in phone stiil same tried another card still same help what can I do ?
I have found the solution i think, the problem with this new update for our Xperia C4 devices it that it is not compatible with exFAT MicroSd Cards and the other problem is that windows doesn't allow you to convert exFAT into FAT32, so i downloaded EaseUS from their web page and i formatted my 128 GB MicroSD (which is obviously exFAT) with it and it is now working with my XperiaC4. Obviously you now will not be able to move files no larger than 4GB. Let me know if this worked for you.
