Whenever i am opening the camera app it displays a message that recording is in progress in another app. Cannot record.
I have restarted my phone but still it is showing.
@shivani16 Usually that message comes up when you have OK google detection from any screen enabled.
Great.
Thanks for the solution to the problem. It has solved it on my Sony Xperia C4 UK. The first time I saw this after buying the phone I put it back to Factory Default to solve it. But then it came back. I had not correlated the OK Google config change with the error as the two events were a couple of days apart. Thanks again.
Do you know if it is a Google App problem, a Sony Video Camera issue, a Sony Xperia H/W issue or an Android issue?
Do you know if it is going to be fixed?
I suppose a S/W work around would be for the Sony Camera App to switch off the "OK Google" feature when it opens and then put it back to the original state when it closes. But probably "Security" will prevent it from changing the setting. We can only hope.
Open Camera, the Google Camera app.,and most third party camera apps, work fine with OK Google detection activated from any screen. This is a bug with the Sony Camera app., not with OK Google.
