forget about what they said that you cant install apps on sd card
you can move apps to sd card in our xperia c did you try that ?
do a factory reset and the memory will become free again ..and install all apps on sd card
I have just bought a new Xperia C and and the specs about the device memory is that 4 GB of internal device memory and i have only 0.98 GB of memory is that a fixed proplem in all Xperia C mobile or just in my mobile and how to fix it to return to 4 GB of internal device memory.
thank you very much.
From 4 GB internal memory,the OS needs some of it.
yes from 4 gb the os takes approx 1.5 gb and the rest 2.5 is for user ...how cant we install app except on 0.98 gb ..you know my old lg android low ranged phone had 4gb and 2.5 gb for apps ..then when i buy an expensive sony one i have only 0.98 gb from 4gb ..is this logic ?
Some of it..... not 90% of the device memory!!!! leving me with only 0.98 Gb of memory!!!
Yes,also apps have updates,which can be pretty consistent in terms of memory.
