- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Power button
Tombol power tidak berfungsi dengan baik.
Apabila mematikan perangkat c3 dual,beberapa detik kemudian akan menyala kembali
The power button does not work properly.
If you turn off the C3 dual device, a few seconds later it will turn on again
gt
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The power button does not work, you have to use the camera button to turn it on. Help me fix the problem, maybe I can correct the error myself.
.кнопка включения не работает приходиться использовать кнопку камеры для включение.Помогите устранить мне проблему может мне удастся самому исправить ошибку.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
I don't quite understand the issue, could you elaborate?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Please help me.
when I mistakenly dialed my own number, the phone stopped working, though the call was not connected.
I can't switch off/restart it since volume and power buttons are not working properly.
I tried removing both sim cards and SD card, but it did'nt shut down.
Worse, it shows as network searching even if there are no sim cards inside it
