Hi
I have been having a few problems with my c5 ultra dual for sometime now.
It's battery discharges very quickly and/ or it turns off radomly when I keep using it for some time.
It has no heating issues. I want to know whether it could be due to a fault in its motherboard? I can make calls and receive calls and do other normal things with it
Please advise , how can I find out if it's motherbard is OK or not
Thanks a lot
Hi
Thanks for reply .
I have done it earlier, both safe mode and xperia repair companion. It has not helped. The battery is still draining.
Could it be because of motherboard fault/damage? How could I find out
Thanks.
@Pp04 wrote:Hi
Thanks for reply .
Thanks.
Bring to authorised service, they will check where is problem. Best solution can be advised only after check of smartphone
Thanks
I have done it. It was battery problem. It's working fine now.
Glad to hear that. I'm happy for you 😉
@Pp04 wrote:Thanks
can you please tell me wht you've done to fix the issue, because i am having the exact same weird battery issue with my c5 ultra
