So I restarded my phone and it's stuck on the blue wave screen forever. Removed SD crd and sim card. Then I tried repairing using Xperia Companion. Problem is it won't start repairing after it initilized. Just stuck on this:
I did all the instructions. I even checked on Youtube if I was doing it right. I did it several times, but no luck. Not sure what's wrong.
Edit: After I reconnect (while pressing volue down), it just goes back to charging. My phone is already at 100% battery. 😕
I have the same problem, please help us
I have the same issue as well.... no idea how to get it to start up or fix this.
Just try to turned your Xperia on into SafeMode. While if in Sony Companion didn't work. Sometime it'll fix when I tried that.
