i have a c5 ultra E5533 model. My phopne is off and keeps on vibrating and does not switch on after i pulled the usb cable in fastboot mode. And now its not turning on? Did i do something wrong in pulling the usb cable out? and i had start the fastboot mode with cmd during which i pulled the usb cable. Plz help me out in this matter. Thanks in advance.
i was going to flash but first i thought i should unlock the bootloader as it was in one of your articles. So any Solution???
@daasbliki wrote:i was going to flash but first i thought i should unlock the bootloader as it was in one of your articles. So any Solution???
I think you are not in right forum. To root smartphone is not recommend by Sony, keep in mind root can void yours warranty, also is not supporting by Sony. I advise you to check information in XDA Developers forum
i was not trying to root. its just that i went into fastboot mode using cmd and when the phone booted into fastboot mode I unplugged the phone from the laptop which is why the mobile is vibrating and and is off and wont't turn on.
