I don't quite understand your question, the notification light should work, just disable the stamina mode and it should work just fine
Hi Ya_Kha,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Are you able to supply more information, is this only for certain apps or does this happen with all applications, does the charge LED work or is this localised to notifications only?
Sorry for this inconvenience.
Do you have stamina mode on?
Turn it off and check again, the "problem" is Stamina mode
Does the LED turn on when its connected to the wall charger?
