No singl on my phon ned helps
Hi @Hassan2017
Welcome to the community!
Sorry to hear about this, have you lost all signal so you're unable to send or receive SMS messages, make or receive phone calls etc?
Let me know
Pls help me.my xperia c4 dont have signal after i upgrade to marsmallow.
@uliwooly wrote:Did you flashed the phone or did you used XC?
In other words @Hassan2017, did you download your new firmware (software) "over-the-air" (OTA - directly onto your smartphone), did you use Xperia Companion to perform the upgrade or was this a custom ROM that you installed?
Also, do you have another mobile device you can test your SIM in? If you're getting coverage with another device, it's probably your smartphone at fault; if you are not getting coverage with another device, you SIM is at fault.
If you could answer these questions, we can continue to help you.
Same problem here i lose signal after flashing marshmallow rom from SAMSONY.NET please help if there any way to fix this problem.
I want ask if i repaire my c4 E5333 using Xperia companion can fix it?
Sorry for my bad english
