Inserté un nano SIM en la ranura de tarjeta SD y quedó atascado
I inserted a nano SIM into the SD card slot and it got stuck
-GT
Hi @Cale, sorry to hear about what has happened.
I have translated your question to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
I would recommend that you do not try and take the SIM card out with any kind of force as it may damage the internals of the device and you should get in touch with the Local support team in your market so they can arrange a repair for you so a trained technician can remove the SIM card from the SD card slot.
I hope that helps!
