HI
My flashlight icon disappears and appears by it self from the active quick settings bar although I did added it and never removed the list
That's interesting. Really - seems like in my case I no longer have a problem since I stopped using TSF launcher and replaced it with Action Launcher... but sorry I can't be certain if the light toggle isn't there just now and tomorrow it won't disappear again :-]
When you slide down where the flash light short cut use to be - there is a pen icon (edit) - click on it. Then you can choose which short cuts to drag into the slide down menu.
The Simple Advice, GOD I feel aso stupid, Spent hours going through every nook and cranny to find the TOURCH tab control, andv DUH there is NOT ONE, and all I had to do was REBOOT my Cell and there is was ! THANK YOU A MILLION TIMES!
