Hello , my phone is hang . What should I do ? I tried to press the power button but nothing. n I tried press power button n volume down and the results is same.nothing happened. The notification glows green and when the charger is plug in green light is appear. Please help me .
You have to press and hold Power & volume UP for 5 seconds
thank you for helping me
@uliwooly wrote:You have to press and hold Power & volume UP for 5 seconds
Anytime
Thanks Bro
