Hi, I recently got hold of a C1905 and love it, apart from two fairly important faults.
The Sleep/inactivity setting keeps changing from my preference of 5 minutes to 15 seconds.
Also, the Mobile Data option keeps disabling itself.
Is there a setting to prevent this from happening?
Or it is this a bug with the hardware/firmware?
Any help would be greatly appreciated as it starting to drive me crazy.
Many thanks,
Kris
Do you have stamina mode enabled? If yes,the option will disable mobile data.
Regarding the screen it may have to do with the setting "Low battery mode" via Settings > Power management > Low battery mode > Screen timeout. Check if this one is set to 15 seconds.
But is low battery mode enabled as Hampus stated?
If you disable it,you can extend the timeout.
Anytime.
