I want to remove the warning of mobile data disabled
Hi @Suleyman, welcome to our forum!
There is no setting to permanently disable this notification. You can remove this notification if you hold down on it with your finger and drag it to the right or left.
Do note that it will reappear again if you reboot your phone or if you turn mobile data on and then off.
I hope that helps!
