Hello ,
how can i change install location to sd card like sony xperia c
wanna use Android folder on sd card for huge games because internal storage space is small
how can i ?
If the option isn't available then I'm sorry to say you can't
But i have heard about something called "Root" that can mount a space from sd card something like that .
can it help or will harm my phone ?
You can root but beware that in doing so you may void your warranty and your DRM keys will be deleted meaning Sony specific features will cease to work
But what to do now ?
should i regret that i bought sony mobile again ?
why is sony xperia C better than C3 ? and how ?
I can't say if you should regret, that is your choice and I don't have either of these devices so couldn't comment on which is better
Can i contact someone from sony developers ?
I'm not sure - I'm a member like you and not employed by Sony
ok , thank you for your reply .
