hi
my screen are broken cant see at all (blank screen)
only can see the upper screen
so before i send my phone to repair, how to wipe my phone data completely?
not the photos, videos etch but sensitive data like facebook, instagram, gmail account where i didn't log out before my screen broke
and im not enabling the usb debugging so i cant mirror my screen to my pc
please help me
have you tried Android device manager or my xperia service
just tried it
how to know if my phone has been erased completely?
all i see some blue color on the top (that's the only part of screen that are not blank)
if i recall correctly that color are from the first thing we need to sign in after bought a new phone, right?
Try to use MyXperia or Android device manager and see if you can locate the phone, if you can't then it has been wiped out
it said Location Unavailable
guess my problem is solved
thank you for both of you
really appreciate it
